TJ Fest 2021
Brand new IR 2135 compressor isn't cutting it
gatertamer
pacific northwest
any ideas on how big my compressor needs to be to use my air guns full capacity....how many gallons...psi...scfm@90. my HBT 8 gal. 5 scfm isn't cutting it and I don't want to buy another that doesn't either.
derekmac
NS, Canada
Are you using 3/8" or 1/4" air line? If it's 1/4", switch to 3/8". But, an 8 gal tank will run out of air very fast. A 5 scfm compressor would be OK for short blasts, but not continuous use, especially with a small tank.
I use a 30 gallon Husky (still only a 5.1 scfm at 90 psi), that also feeds a 20 gal slave tank. It works great for my impact, but a die grinder will drain it pretty fast.
This is the compressor I use: https://www.homedepot.com/p/Husky-3...table-Electric-Air-Compressor-C303H/206532808 I'd recommend one with a higher scfm though. Getting a higher output one generally requires a 220 outlet.
gatertamer
gatertamer
pacific northwest
I use 1/4inch....so you think it may be width of hose and not scfm or HP or PSI...does more HP or PSI equal better performance?
derekmac
NS, Canada
The 1/4" hose is restricting the gun. Think of it as trying to drink through a thin juice box straw compared to a big milkshake straw. You get much better flow with the bigger straw.
Also, if you want to run the tool at 90 psi, you should set the regulator while the tool is running.
More HP equals higher scfm, which will give better performance and quicker tank recovery. Generally ignore the HP ratings on big box store compressors though. A normal 15 amp house outlet "might" run a true 2 HP motor, if it's close to the breaker panel.
Rob5589
Certified video trained differential rebuilder
W Sacramento, Kalifornia
Like Derek said, 8 gal runs out too quick. My compressor has a 27 gal tank and runs about 6 cfm @ 90 psi and it runs out too quick at times.
Definitely check pressure while running tools. Hit the trigger and check the gauge. Mine is set at around 110 psi and drops to 90 while in use.
59 wagon man
Hollywood, FL, United States
it will be hard to run a good 1/2" impact gun on anything 110v. 220v is your friend. I have a 5 hp I think it is 50 gal upright in my shed probably 10 yrs old from harbor freight
Jerry Bransford
TJ Guru Moderator
Staff Member
Escondido California
Switching your air line to 3/8" is likely what you need to do, 1/4" just can't flow as much volume as 3/8" can.
You don't need a 220v compressor to run even high CFM consuming air tools. I installed 220v in my garage for my welder but my 110v compressor runs my air tools using 3/8" air lines without problem and sometime nearly continuously like if I'm running a grinder or polisher without problem. Heck even my York a/c compressor I converted for use as an OBA compressor in my previous TJ ran my 1/2" IR double-anvil impact wrench on the trail or at the auto parts recycling yard without any problem whatsoever.
gatertamer
gatertamer
pacific northwest
again thanks...I think I learned to go with a bigger line...bigger tank...and scfm isn't that important....should I run my tool and at the same time set it to 90psi immediately or wait a sec?...the longer you hold the trigger the more the psi drops
Jerry Bransford
TJ Guru Moderator
Staff Member
SCFM is very important but your 5 SCFM should be plenty. Especially for a lower CFM consuming tool like an impact wrench. High CFM consuming tools are things like paint sprayers, polishers, grinders, etc.
Reactions: gatertamer
Rob5589
I hit the trigger, watch the gauge, then adjust as needed. CFM is important but some tools use more than others. Air ratchet, die grinder, air chisel, use large volumes of air.
Reactions: Jerry Bransford
gatertamer
gatertamer
pacific northwest
I guess i'm still missing something...I have 3/8 hose with 1/4 inch fittings, do I need 3/8 fittings on the hose?, and the 3/8 fittings don't fit my tools, do they make 3/8 that fit into the standard air tool openings?, or is there some sort of reducer (counterproductive)
gatertamer
gatertamer
pacific northwest
thank you I just ordered some....are 3/8 hose and 1/4 fittings the norm?...people keep saying go to 3/8 hose are they using 3/8 or 1/4 fittings?
