any ideas on how big my compressor needs to be to use my air guns full capacity....how many gallons...psi...scfm@90. my HBT 8 gal. 5 scfm isn't cutting it and I don't want to buy another that doesn't either.
Pull the trigger for a few seconds, then adjust the regulator to your desired pressure.should I run my tool and at the same time set it to 90psi immediately or wait a sec?
SCFM is very important but your 5 SCFM should be plenty. Especially for a lower CFM consuming tool like an impact wrench. High CFM consuming tools are things like paint sprayers, polishers, grinders, etc.again thanks...I think I learned to go with a bigger line...bigger tank...and scfm isn't that important....should I run my tool and at the same time set it to 90psi immediately or wait a sec?...the longer you hold the trigger the more the psi drops
Yep, 3/8 hose with 1/4 fittings is the norm.thank you I just ordered some....are 3/8 hose and 1/4 fittings the norm?...people keep saying go to 3/8 hose are they using 3/8 or 1/4 fittings?
