Break-over and departure angles—I'm an odd duck
Semi trucks with saddle tanks only have to fill one side, just sayin'. ;)
i'll peek into that, the tie tube would have to be low and fill the 2nd tank up ^ literally, to keep it low enough from intrusion.
lemme edit this to add now........i'll pass on needing a kicker pump to do that job. if i could tie a tube at the top level and pass it through cab in a position that might be supported by a simple addition to the roll bar to support and protect it then i'd consider it.
part of the whole idea was keepin it simple. the saddles dual gravity feed the pump can, their small footprints make starvation of the gravity lines highly unlikely. the pump would stay max submerged, always, in it's can. and have to drain it's 1/2-3/4gl holding can and both lines b4 it could suffer any starve issues.
the 2 small cells are available. the small pump housing would need constructed custom based on pump choice.
but it does seem like a hassle and i'm ready to just drop in a box and doctor it up to work well.
