Broken easy out inside a broken bolt
Hammer24
Melbourne, Australia
I've found myself in quite the pickle here. The other day we had super high winds and i opened my door, and it swung out so hard that one of the bolts snapped holding that little loop for the door strap. I tried to use an easy out and the easy out bit snapped inside the bolt so now I can't even re drill the snapped bolt because the snapped bit is hardened steel. Anyone have any ideas or am I just going to have to drill a new hole to the right of the original and rivnut it.
CharlesHS
Lifetime Supporting Member
Jacksonville, FL, Quezon Philippines
Walton makes a tool that will remove broken taps.
Walton Tool
Stinkbug
Huntington Beach, Ca
I think I would just consider relocating the bracket rather than invest in a $60.00 -$90.00 in a solution to remove the broken extractor. However if I routinely ran across rusted bolts in my restoration projects, I think that Walton set would warrant additional investigation.
Reactions: Rubicon88
Wingback73
Massachusetts
No reason to panic - you simply need a different bit. Same exact thing happened to me on my rear upper shock mount. Bolt broke, easy off broke, life sucks.
The only reason this is an issue is because easy-outs are hardened - so much so that it is harder than your drill-bit.
The solution, of course, is nothing other than getting a better drill bit.
In my case, for space reasons alone, I used my dremel with a carbide tipped bit in it to create a small crater in the middle of the easy out, then switched over to split-point carbide I ordered through Amazon.
When I broke off the Grade 8 bolt in the shock bump stop I skipped the easy out and went straight to the carbide. Drilled right through it like nothing at all.
d-
Hammer24
Hammer24
Thanks for the suggestions guys, might look into some harder cobalt or carbide bits as I can't seem to find those other options available near me. I can get some left handed cobalt bits, could be a good option?
Claybirdd
Alabama
Carbide drill bit at low speed and plenty of oil (not WD-40) to keep it cool. Its likely when you tried to drill it out before the material got way to hot essentially case hardening it.
Make small pecks while blowing out chips and re-lubing in between cuts.
JeepingNet
Saint John, NB, CA
Left handed cobalt are perfect! Sometimes you’ll get lucky and since it’s spinning to the left it will also act like an easy out.
dom.robles
Orange county
i was doing a bedliner on the tub and snapped 3 of the 4 bolts that hold in the rear seat brackets. they wouldnt come out after a night in liquid wrench and a screw extractor. i ended up drilling through 2 of them and decided maybe i could try the extractor on one last bolt since its been sitting in the liquid wrench the longest. bad idea. screw extractor snapped off right inside the bolt and i couldnt drill through it anymore. i ended up installing the backseat with only 3 bolts because i needed to drive family to the airport but i'd
like to solve this problem the right way. maybe i'll see if i can find a carbide bit bc ive broken 3 of my milwaukees. rough day,
