OK...so the deal is done and now I just have to go pick up the Dana 44 rear/3.73 AND Dana 30 front/3.73. My question now is, my son’s Jeep’s PO did tell me he had to replace the drive shaft within the past 2 years. He said he had it replaced with a “heavy duty shaft” with eliminator as the previous shaft didn’t have one. Looking at the angles the previous shaft must have been in (fairly steep), should I assume there could be damage to my son’s Jeep’s transfer case as well? The reason I ask is because the seller I’m getting the Dana 44 from has the transfer case available too...
The Tcase should be fine. The swb TJ does not take much lift before needing driveline modifications, about 3" and over you should be using a slip yoke eliminator and double cardan driveshaft. There are other ways to do it but they are "workarounds" to the correct way.
Going from the Dana 35 to the Dana 44 will need some driveshaft changes. Shortening and possibly a ujoint change. You will see all that once it is mounted.
