Back to my trailer, I’ve been spinning over the tie down method since I picked it up.
I wanted to used axle straps but after trying them under load there is no clear place on either axle to get a 2” strap over it without chafing on a sharp edge.
At the suggestion of many I looked at (even bought) tie down brackets. On the rear Currie Dana 60 axle without outboarded shocks that forces me close to the differential or up on the track bar and UCA mounts. Those positions are doable but not ideal.
However, there is no reasonable location on a stock width Currie HP44 front axle to mount brackets. You could put them on the underside of the axle but then they will be right in the line of fire for rocks. This was not going to work for me.
So, I came back to the idea of wheel nets. I called Mac’s to get a quote: $650!
Looking around I realized that I could make my own wheel nets with off the shelf parts from US Cargo Contol that cost $204 all in. Same load rating, just using a ratchet on both ends instead of a snap hook on one side.
This allows me far more adjustability in case I later change wheel sizes or need to haul another rig with different size wheels or wheelbase.
I got tie down track sections and fittings rated for 5000 lbs each and mounted the track over a frame with the center bolt in the frame. The other two bolts have fender washers under the 2x8. The 2x8s have been tied to the frame with additional fasteners.
I thought about putting track all the way down the trailer but these local sections will be easier to keep clean and I can also ensure I am mounted through a frame by doing it this way.
Happy to hear any inputs on this configuration and happy to call it good.
The front strap is close to the ball joint however the top section is protecting the loaded strap so I think it will be okay and I will closely monitor it and add more protection if I see wear.
