Yesterday was a bust looking for the correct trans cooler hose all over town. All the shops carry a thinner walled hose than came with the Derale kit. The difference can be eyeballed even if the dimension is not much larger. As a last hope to match it I’ve got some Gates hose coming in from Amazon. In the meantime I’ve got four of the six fittings needed and the other two coming in from Amazon. I will reuse the two fittings from the radiator so I can have a 90 degree line and the other I’ve bent just a bit to use on the upper port of the trans where it is close to the tub.
The hose in the Derale kit is on the left.
While waiting for parts I used the time to move the Jeep out of the lift bay to wheee I’ve got more room to work on the armor and cage. I also got the hard top off and stored but before that I put on new struts and some mounts in the back for a hoist.
I also tested out my lightweight spare tire mount. I have a Yakima mount as many would put on their roof rack. It uses a loop and a hook to secure the tire. Instead of using the loops they provide (attached to a steel plate), I made an eyelet that screws into the back seat center seatbelt hole. If that can secure two people then it can handle a 35” tire, at least in my view. The whole thing weighs maybe 3-4 pounds. I can lock it if I want to, another nice feature.
