Yea I’ve been meaning to get quotes for the job. Once the springs are straightened out, does it add more lift in the rear vs when the coil spring is arched before relocating the perch?
It depends. I lost a bit of ride height by trimming the mount so it sits higher in the frame arch. That is one reason why I run Currie LJ coils in my Tj. I think if it is just slid over, the ride height does not change.
do you have a MML and or low pro trans mount? Im currently at 2.5" SL with a 1"MML and 1.25BL, ive got some 3" springs and the ucf ultra high skid/lo pro mount to go in, obviously with a SS SYE etc. Im hoping I wont get bad vibes/angles with the MML and the lo pro mount
