So I'm in the process of swapping out my front suspension. I first jacked up the Jeep and put 2 jack stands on the frame so I could droop the suspension to take any load off. Then I took the driver's side shock off, then passenger. Next I pulled the driver's coil spring. Up to this point everything had gone pretty smoothly. But after working on the passenger's side spring for about 20 minutes with using a jack on the axle to use the articulation to help get the spring out and everything, I decided to to rent the spring compression tool at the local O'Reilly's. I've used these before so I knew to be cautious and all of that. But after fudging with that thing for a while it was back to using 2 hefty screwdrivers to leverage the spring out. I got the spring off the perch finally. But I spent another 20+ minutes coaxing the spring out. I removed it on the backside of the axle, between the upper control arm and the axle. I used the spring compressor tool a little, but not sure it helped much. My main issue was the bump stop tower(?) or jounce? I don't know if the ones on mine are abnormally long or what. I'll attach pictures for reference.
I obviously need new bump stops too. Can I cut these upper ones down to make it easier to install the springs and do the hockey pucks on the spring retainer? Or what bump stops are widely recommended here? Not looking to break the bank, so if you're coming in saying "I'd do the Teraflex Speedbumps if I were you" don't even bother.
And forget about getting the new springs back in tonight. I'll have to see if another store has a different style of spring compressor because this one is a joke!! It has 2 arms with a hook on the end to grab onto the coils and then a long bolt/shaft and on the other end it has some captured washers and then this curved fork looking thing that is retained by the washers. Does it compress the spring? Yes. In concept does it do what its title is? Yes. But the issue is you have to put the dang tool on the inside of the spring!! How the heck am I suppose to reinstall a compressed spring with an 10-12" long bolt in the center?! Like how do I get the tool back out once the spring is in place? Doesn't make sense to me...
(not compressed)
(not compressed)
