2003 Rubicon. Throwing codes P0340, P1391 and P0300. Running rough when calling for power (acceleration and upshifting) some backfiring. Cannot find a Mopar anywhere. Replaced CPS with a Delphi from rock auto. This made it much worse. I switched back to the old one after 10 miles. Does anyone have knowledge of what brand might work? Also, would it make a difference if i replaced the crankshaft position sensor at the same time with the same aftermarket brand?
I did read related threads, especially helpful was one from "sab" posted april 2, 2023. This went into great detail on the relearning process. I am making the assumption that I do not need to go through a relearning process because I did not replace or remove the synchronizer. I simply replaced the sending unit on top.
Thank you for any input.
