My AC compressor is not turning on, although my system is charged. My mechanic suggested that the PCM might be bad. Has anyone experienced this problem?
The PCM does energize the A/C compressor clutch relay's coil by grounding it based on the dash control switch positions and the A/C pressure switches, so it is possible that it is the problem, but there's a whole lot more to diagnosing it. In order to properly diagnose, I'd start by turning the A/C on, and then check for ~12V on one side of the relay coil and continuity with ground on the other side of the relay coil. If the 12V side isn't 12V, it's something from the fuse to the relay (including wiring harness). If the other side doesn't have continuity to ground, more diagnostics is required to rule out the pressure switches, the compressor, low or high refrigerant, and the PCM. If both sides of the coil are good (one has ~12V and the other is grounded), then your diagnostic lens should be pointed at the power to the A/C clutch (start at the fuse in the PDC and work to the clutch, checking for ~12V the entire way). Here's the wiring diagram for my 2005 LJ Rubicon to show you how the A/C logic works (you can get the full manual for yours from here):
