You can only tuck the driveline up so much before you hit the tub & even then without a stretched wheelbase your driveline angle is going to be really sharp. You also don't want a Constant Velocity Driveshaft either, you probably mean a Double Cardan Driveshaft.If you already have a 1.25" BL, what would a 1.5" or 2" MML do to the driveline as far as a mini TT is concerned? Could this eliminate the need for a SYE and CV?
Yes, DC, for some reason everyone just says CV. Thanks for the correction!You can only tuck the driveline up so much before you hit the tub & even then without a stretched wheelbase your driveline angle is going to be really sharp. You also don't want a Constant Velocity Driveshaft either, you probably mean a Double Cardan Driveshaft.
Yeah, Tim responded to my inquiry. Here's his response...
"So many questions. You should NOT use a 1.5 or larger MML on this set-up at all. You could do damage to the driveline. With only a 2.5 suspension lift, you should be using stock height motor mounts at this point. In the range of suspension lifts, we consider a 2.5 in the same category as “no lift” because the effect is negligible.
An SYE and CV should not be a consideration with a 2.5 in lift as far as driveline angles go.
One other question: Why are you considering a tummy tuck on this set-up?"
Solid advice. At 2.5 of lift you don't need a MML.
Not in all cases. When I installed my OME 2.5" lift, I had terrible rear drive line vibes, and ended up having to lower my TC skid 3/4" to eliminate the vibes. Would a MML helped my situation? Maybe, maybe not.
That's what I told Tim. I had vibes at 2.5" and so I added the TCase drop. After a couple of months I ordered his 1"MML and I was able to remove the TCase drop. So it solved my vibes problem...True, most people just drop the transfer case in that situation. But a MML may have.
There are a number of ways, only one way to do it correctly.There ya go, that works then.
There's a number of ways you can achieve the proper driveline angle, an MML is just one of them.
And it is?There are a number of ways, only one way to do it correctly.
By removing your stock driveshaft and installing an SYE/DC Driveshaft Combo.And it is?
Yeah, it’s no guarantee there won’t be other problems. I’m sure a solid install with solid parts and no other issues that might interact unwontingly would be perfect. Maybe I’m being silly by being scared off.That's what I was thinking, but even that is no guarantee.
With adjustable rear arms to dial in the pinion angle.By removing your stock driveshaft and installing an SYE/DC Driveshaft Combo.
It may not be a 100% guarantee but if you bring me 100 rigs to fix that problem on, I can do it on at least 99 of them. Of that 99, 90 of them will be cake and 9 of them will be a PITA but we'll get it. We've only had one that was problematic enough that we had to put a hub kit on the front to get rid of vibes. I know of a couple more like that but not that I've worked on personally.That's what I was thinking, but even that is no guarantee.
