Can I fit 33s with a stock jk lift and wheel spacers
Mason Canner
Long Island, New York, USA
Hi everyone, Im planning on putting on the Stock JK suspension on my TJ (3inch lift from research). Would I be able to run run 33s with no problems. I do have 2 inch wheel spacers, if those help. Thanks!
3" of suspension lift is not quite enough for 33's for offroad use, I recommend adding a 1" body lift. 3" would be enough for smooth street use but not quite enough for offroad use.
I had to do a 2.5” OME with a 1.25” JKS Body lift. You might be able to get away with just the 2.5” lift but your fenders might take a beating if you articulate at all. Just street prolly can be done with just lift
No JK front springs are going to give you 3" of lift. Only 59 or 60 rear springs are going to give you that much lift also. What spring numbers did you get?
