RHanna TJ Enthusiast Supporting Member Joined Oct 27, 2020 Messages 787 Location Gallatin, TN Nov 13, 2022 #1 Can I install a warn 97730 on a TJ? Warn M-15s I know it’s overkill just curious
L LukesfirstJeep TJ Addict Supporting Member Joined Aug 2, 2018 Messages 1,410 Location Central PA Nov 13, 2022 #2 I don't know. Per Warn's webpage, it has a CA Prop 65 Warning. I'm sure it will fit. Compared to a M8000 winch, the max amp draw increases from 435 to 460. I don't know if that makes a difference to the TJ's electrical system.
joe98tj TJ Enthusiast Supporting Member Joined May 8, 2020 Messages 306 Location Connecticut Nov 13, 2022 #3 It has the typical 10" x 4.5" bolting pattern and slightly higher draw than their 8k winch. What are your concerns about installing one?
OP RHanna TJ Enthusiast Supporting Member Joined Oct 27, 2020 Messages 787 Location Gallatin, TN Nov 13, 2022 #4 joe98tj said: It has the typical 10" x 4.5" bolting pattern and slightly higher draw than their 8k winch. What are your concerns about installing one? Click to expand... It looks like it uses foot front mounting and 2 on the bottom similar to the 8274. I guess I could get a 8274 winch mount and use that to mount it
Blackjack Evil Winch Doctor Supporting Member Joined Dec 16, 2018 Messages 3,971 Location Kenai Nov 13, 2022 #5 If you really have to run one you will have to fab a mount. The 8274 mount is too narrow. Reactions: RHanna
