I just did a drain and flush last week when I did my water pump. Make sure you pull the block drain too. I pulled my heater hoses off and flushed them too. Some people get uptight about not using distilled water, but if you pull the block drain, open the radiator petcock, and the heater hoses, and let ‘er rip with a garden hose, it WILL all drain back out. Then I hooked up everything, and refilled with the Zerex GL05 mixed 50-50 with distilled water. That’s where having distilled actually counts.
And one of these type of funnel kits makes things way easier as well.
https://www.amazon.com/dp/B01A2CQSU6/?tag=wranglerorg-20
