I'm not opposed to it and have trimmed them a couple times. In this instance I'm just looking to not do that, unless there aren't other alternatives.Trimming the lower perches is no big deal for some added clearance.
Well, if the Black Max's work out for you, you can mount them either way for added clearance.I'm not opposed to it and have trimmed them a couple times. In this instance I'm just looking to not do that, unless there aren't other alternatives.
Extra clearance, plus the shock body won't get beat up from a gravel road I travel on!Well, if the Black Max's work out for you, you can mount them either way for added clearance.
That's a good thing if they can be mounted either direction, I was disappointed to learn my RS5000x shocks couldn't be mounted upside down in the rear.Well, if the Black Max's work out for you, you can mount them either way for added clearance.
That was a requirement I was looking for. I'm expecting these to be a very soft ride. The question is going to be how soft are they? I've had Zone, OME, and Bilstein shocks in the past, with my favorite being the softer Zone shocks.That's a good thing if they can be mounted either direction, I was disappointed to learn my RS5000x shocks couldn't be mounted upside down in the rear.
My RS5000x shocks reminded me of the ride and control my previous OME Nitrocharger shocks gave.That was a requirement I was looking for. I'm expecting these to be a very soft ride. The question is going to be how soft are they? I've had Zone, OME, and Bilstein shocks in the past, with my favorite being the softer Zone shocks.
X2 for me, as I ran the 1st gen OME Nitros for 10 years. I plum wore them out till they puked!My RS5000x shocks reminded me of the ride and control my previous OME Nitrocharger shocks gave.
I'd buy another set of them if they still made them, it was a great shock.X2 for me, as I ran the 1st gen OME Nitros for 10 years. I plum wore them out till they puked!
Same here. I switched back to the Zone shocks from the Rancho.with my favorite being the softer Zone shocks.
You felt Rancho RS5000X was too stiff?Same here. I switched back to the Zone shocks from the Rancho.
Just slightly stiffer on the little bumps on the street than the Zone shocks. Much better on the big stuff and offroad though. I just can't win.You felt Rancho RS5000X was too stiff?
Driven mostly by the fact that their compressed and extended lengths are good match for my needs, I pulled the trigger on a set of Black Max shocks. Based on what I've been told, these can also be run can up or down. I'll find out for sure once they are received and installed!I messaged Rancho about this a couple years ago and they definitively said that they cannot be flipped.
https://wranglertjforum.com/threads/upside-down-rancho-rs5000x-shocks.25326/
