Can't get out of 4 low
Fouledplugs
TJ Guru
Alabama/South Carolina
I had it on a jack and lowered it to where it needed to be. But I feel like something still could’ve gotten bent.
The transfercase and transmission needs to be supported when you lower the skid plate. You bent the linkages when you lowered the skid without supporting the trans and case. The service manual would have saved you here; as it instructs you to support the transmissions and transfer case when lowering the skid plate.
You will have to lower it all again, supporting the trans and transfercase and unbend everything and re replicate the linkage to what the factory provided.
Daryl
2004 Rubicon
Earth 🌎
It is at an angle because I dropped my skid plate. Don’t have an SYE yet.
When you drop your skid plate or install a body lift you need to address the mechanical linkage alignment. Either drop the body side mount bracket or purchase a cable shifter. Your choice.
scottgraham
Just another bad habit
land of waterfalls
So in a nut what we are all saying is that the skid plate holds up the TC and trans.
If it was not FULLY supported when you dropped your skid, you bent or broke something(s).
Tank97
Tank97
Branson MO
okay guys. Update for you. I bought a SAVVY cable replacement and installed it. Apparently that is not the issue because I sill cannot get it out of four low. Could I have damaged something within my TC? Or what could cause it now to budge at all. I got behind the lever with a screw driver and pryed at it while someone in the cab tried to push it out of 4 low. Still no result. Please help.
Daryl
2004 Rubicon
Earth 🌎
The driveshaft may need to be turned ever so slightly so the gears in the transfer case will align.
Tank97
Tank97
Branson MO
Hello all. Having issues with shifting my TC after installing a cable shifter. Is it possible that I got the wrong cable shifter or installed it wrong? It won't budge at all. Or is it possibly the transfer case itself.
CodaMan
California Prisoner (for only a while longer)
California (for now)
I found it easiest to have the in-cab lever up in 4lo, manually put the TC in 4lo and install and adjust from there. It only took one try.
tr21triton
Blue Ridge' Ga
like to see him driving down the highway... hopefully he has a loud exhaust. 6k rpm's and doing 20 mph ! :ROFLMAO: kind of like the 50cc motorcycle poker run they have up here on Halloween ! you hear this bike for 5 minutes just screaming down the hwy, then when you finally see it you could walk faster than its going !!!!!! 😭😭😭 i look forward to it every year, sit on the porch with some beer's and laugh my ass off all day. oh and alot of them have costumes on for added entertainment
Tank97
Tank97
Branson MO
Hahaha. Yeah, you know me. Just a irresponsible jeep owner. JK. I got it in 2 hi when I first posted questions but haven't attempted to shift into anything else until this last week. Thank you CodaMan and CharlesHS for the advice. I will give it a try my next day off.
If I am unable to shift my TC manually than what is my next move? Rebuild TC?
