TJ Fest 2021
Can't get rear track bar to line up
gbirk
Oregon
When I did mine, I did not have a ratchet strap availible so I just wedged a small bottle jack between the bar and something else and pushed it into place. It really did not take much force, just more than I could provide by pulling on the bar.
freedom_in_4low
Monument, Colorado
Yes, really anything will work. Even a helper to push while you put the bolt in can get it done, especially if they have a wall or another vehicle to push off of.
WallyWest
PA
Ratchet strap, or find a helper that will just push on the rear fender. It usually doesn't take much force to get it lined up.
Jerry Bransford
TJ Guru Moderator
Staff Member
Escondido California
Since your track bar grew used to being connected to a higher situated mounting bolt hole, my bet is you just need to jack the frame up an inch or two to get the bolt holes to line up again.
