I'm changing a u-joint but I didn't want to mess with the axle nut. I got the three bolts out, shouldn't it come off now? I guess it's rusted together. I've been hitting it with a mallet. Are there any tricks to this or is there a better way?
Thank youHere you go, that's a common issue... https://www.stu-offroad.com//axle/unitbearing/unitbearing-1.htm
I beat on the joints, nothing moved. At all. I don't think i bent the ears yet, but I'm done. I may be able to cut the u-joint in half then beat them out, but I really don't see another way. I can't tell what's u-joint, cap, clip, or just rust. I'll try to take a pic tomorrow. Hopefully my other car's battery takes a charge overnight so I can make it to work.Are the ears on the axles bent? Are you sure you can’t save them?
Can you clean them up and smack the joints out using a hammer and block of wood?
