Finally started to knock some things off my to-do list this weekend. Ball joints, inner axel seals and pinion seal. Ball joints replacement went well, but when I took the gear set out to get at the seals I noticed the driver side carrier bearing and cap were in bad shape. The only shims I see are under the bearing.
The bearings are Koyo, (see picture) do they need to be the same ones I replace with, so the specs are the same? I would replace both sides even though the passenger side isn’t bad. I’ve never replaced carrier bearings or messed with gears in general so I’m a little apprehensive. I would think if the width of the new bearing is different I would need more/less shims?
I’ve watched a couple videos and it looks like either the clam shell puller or cutting them off is the go to. And then installing using a press.
Is this something I should just bring to a shop to handle? If so, do I reassemble and drive there or can I just bring them the carrier?
Thanks in advance for any assistance you can share.
