My TJ has the NV3550 and also has 160k on the odometer...I have zero clue about its maintenance history so I'm curious as to if I should mess with the trans fluid at all...I have absolutely ZERO issues with the transmission and I have heard if the fluid has never been changed that more or less the transmission gets used to running with all the build up in it and if you drain it and put fresh fluid in, it may not run correctly...so being that it is somewhat high mileage and has zero issues should I leave it be or go ahead and put some fresh redline in there?
