I have finally had my jeep re-geared after having no 4wd for who knows how long it feels so nice to use it, I also have a air locker in the rear now
I've said before that I wheel a lot with 1st, and some 2nd, Generation Broncos. Most run 37" tires and heavier wheels. All, with the exception of one, are on completely stock 44 fronts and V8s. The only thing I ever see broken is an outer U joint or blown hub.Yeah...until you look at a real Dana 44 out of a chevy or ford...
The Dana 44 front axle in a TJR is definitely more marketing than beef. It has more in common with the Dana 30 than with a "real" Dana 44.I've said before that I wheel a lot with 1st, and some 2nd, Generation Broncos. Most run 37" tires and heavier wheels. All, with the exception of one, are on completely stock 44 fronts and V8s. The only thing I ever see broken is an outer U joint or blown hub.
Hold off until you can get the SS SYE. The longer you can make the already short driveshaft, the better off you'll be.So I have a question, now that the re-gear is done my next project will be a SYE, my question is should I get a super short or standard length SYE? I have 3 inches of lift and I'm gonna do a slight tummy tuck after the SYE,
Money is kinda tight for me so that's why I'm asking, if I had the money I would deff go with the Super Short, I just want to know if it would be necessary?
thanks so much!I just read through your whole build.
Great job!!!
Keep it up!!!
It looks like the PO put a K&N sticker on the evaporative canister.ive got a question, so my jeeps PO installed a KandN CAI but there is another thing under my hood that has the KandN logo and im not sure what it is, can someone help identify it?View attachment 278334View attachment 278336
yeah I just went and took the sticker off, good riddanceIt looks like the PO put a K&N sticker on the evaporative canister.
Pics never do it justice…did some Epic stump crawling in my backyard
View attachment 278305View attachment 278306View attachment 278307
the stumps are bigger than they look
