2001 2.5 5 sp 108k.
My problem - jeep will not start. I doest not sound good/normal while turning over. Its like the timing is off. It turns then seems like its struggle to turn over. I now see small puddle of oil in the intake manifold looking through the TB.
The weird thing is she was running "fine" except for a rough idle. I was just trying to make it smooth. All I did was removed the TB and all attached sensors and cleaned thoroughly with carb cleaner then reinstalled. I also changed the plugs from Autolie AP 985 to XP985. I'm sure all plug wires are where the should be.
First attempt to start was good it started but would not idle. I thought maybe I sleeve on the TPS was hung up. Removed checked and reinstalled. Tried starting...difficult turning over...turns...then struggles. I pull the plugs and they are covered in black. I tried to put the old plugs back in. I've checked the firing order. Not sure what to heck I did but hoping someone have some suggestions. THANKS
