Cleaning out the back for new paint
TheShakes90
NM
Anyone know what this stuff is? Figured I'd ask before I hit it with the angle grinder
thomat65
Southwest MI
Is that a plate glued down to cover a hole? With some kind of lining applied over top of that?
What did your angle grinder say?
hosejockey61
Parker, CO
It's seam sealer. You can scrape it off with a painting knife or the like. Might be better to leave it and paint over it.
Reactions: TheShakes90
hosejockey61
Parker, CO
I wonder if a little heat would make it more pliable and easier to scrape out, if OP wants to
Heat will make a big difference. I just pulled my rollbar out recently and use a mapp torch to soften that crap up. The bolts holding the roll bar were covered in that stuff and I had to dig them out to remove them.
Reactions: thomat65
TheShakes90
TheShakes90
NM
@thomat65 hopefully there's no inkling of rust under it. Main reason I'm doing this is to prep for lining the rear, there's a couple of small surface rust spots I want gone before I even think about the lining though.
