There's a new noise coming from my front axle. It's started making a clicking/popping noise when I make a sharp turn at low speed, e.g. when parking. The noise can happen at very low speeds with very light load.
The obvious culprit would be a failing u-joint. To diagnose the problem, I took some GoPro video of it happening with shots of both front u-joints. I also checked the u-joints by spinning then by hand while steering to lock. That was all inconclusive. I didn't see any signs of binding or play in the u-joints.
However, in the GoPro video the clicking/popping sounds seem to be coming from the front diff. I have an open Dana 30 that last had a fluid change about a year ago.
The diagnostic guide in the FSM says that a low speed knock (which sounds about right) could either be a worn u-joint or worn spider gear thrust washers. So it could be the diff.
I'm about to crack open the diff to inspect it, but if it's just wear on the washers there may not be much to see.
It would be nice if I could figure out what needs repair before I order parts. Any suggestions on how to diagnose this?
