Clunk From Driver Front Wheel (U-Joint or Wheel Bearing?)
JHammett
It doesn't go any faster...
Gilbert, AZ
Hi,
I have attached a video below of a clunk/knock I am hearing when going slow coming from the front driver wheel area. I assume the noise is there at higher speeds as well just less noticeable due to other louder noises (wind resistance, humming MTs). In the video I am coasting with the motor off to get rid of as much sound as I can. Hopefully you can hear the clunking. Sorry for the IPhone quality video.
A bit of context, I recently put in new axle shafts from Revolution so I pressed new Spicer U-Joints in as well as put in new ball joints and new Timken wheel bearings (while also putting in the BMB Big Brake kit). Is it possible that I messed the U-Joint up or have a faulty wheel bearing?
Any other ideas?
Much appreciated.
  • IMG_7819.MOV
    22.4 MB
JHammett
JHammett
Gilbert, AZ
I swapped the front wheels this morning and it seems to now be louder on the passenger side, which I would guess means that tire needs to be rebalanced. Will take it in later today to get them to rebalance.
AndyG
Because some other guys are perverts
Lifetime Supporting Member
Alabama
Good move-
All Tj front shafts also need to be maintained- if you ever hear it squeak pull it.
JHammett
JHammett
Gilbert, AZ
I just got the front tires rebalanced and I can still hear the sound when coasting at slow speeds. I am posting a Video below of spinning the front tire with it jacked up. Let me know if you see or hear anything out of the ordinary. I do have an Auto locker up front.
  • IMG_7820.MOV
    26.7 MB
JHammett
JHammett
Gilbert, AZ
Found the culprit. The passenger axle shaft u joint had a little bit of play in it. I was sure it was the driver’s side where the noise was coming from so I never checked the other side. All is good now.
TheBoogieman
Disturbed American
C-Ville VA
Replace them both with Spicer u-joints.
CharlesHS
TJ Expert
Jacksonville FL, Quezon Philippines
Interesting you found "A little bit of play in the passenger side axle shaft U joint". In Post #1 you stated you installed new Spicer axle U joints with the Revolution axles. There shouldn't have been play in the U joint unless there are some need bearings missing inside the U joint cup or the ears on the axles are out of spec.
JHammett
JHammett
Gilbert, AZ
I also found this interesting. I took the u-joint out yesterday expecting it to be missing needle bearings, but all were there undamaged, clean and greased. I then checked the rest of the u joint and everything seemed in perfect order, so I repressed it in and reinstalled the c clips.
If this happens again I will maybe try another u joint (I have a brand new spare 5-760x on my workbench) or reach out to Revolution. Perhaps the ears are marginally too wide allowing the caps on the u joint to slip. These are the Spicer 5-760x u joints that come with the Revolution shafts.
I am hoping that I installed this poorly last time. I know I was in a rush when I was pressing them because I was late for something. I just can't imagine that I would have installed it with the amount of play it had when I removed the shaft last night. I think it would have been noticeable.
