Had this irritating clunk at low speed over small bumps or dips driving me nuts. Clearly seemed to be a suspension issue on the right side. First addressed sway bar torque setting which needed of some tightening but that failed to solve the problem. Then disconnected the links, and the clunk was gone. Assumed the links were the problem but could not find replacement bushings locally. Not wanting to drive the highways without the links, I decided to reinstall them with a liberal amount to grease to the bushings, sleeves, and bolts before re installation. Also reversed the top and bottom of the links because of a difference in the wear patterns. Now have tested it extensively. The clunk is gone. Just hope it stays gone.
