I just replaced my master and slave cylinders in a 2000 Jeep Wrangler TJ and the clutch is still loose. The replacement said it was pre-bled, but I bled it again hoping it would fix something. This temporarily solved the issue, but the clutch went loose again after a few pumps. It isn't falling to the floor, simply pushing in with almost no resistance before jumping back to its original position. I filled up the brake fluid, and I pumped it about more than 50 times as one other discussion thread had suggested. I feel like I have done everything to fix the problem and the replacement parts are brand new and not leaking so I'm not quite sure what the issue is. Any help would be much appreciated. Thank you!
