Clutch Replacement
Charles Hayes
Hey Ya'll, I replaced the clutch in my 2003 Tj. The Job went pretty smoothly, however the clutch is now so light it dosent even feel like it's there. It shifts into gear as smooth as can be. But I just can't get over how I can barely feel the clutch and it engages almost at the top pf the clutch travel... Is this normal or should I be worried ?
macleanflood
I break sh!t
Fall Creek, OR
You can get a pre bled Luk master/slave kit reasonably cheap.
I'd swap that before I pulled the transmission to see if something is wrong.
What clutch did you use? Did you change the pressure plate? Throw out bearing?
-Mac
P man
Keister Bunny
Washougal Wa
I'm confused..so the clutch feels light but works perfectly? Why would you change anything? No grinding? Hard to get into gear?
