So I don’t have the money for a winch but I have seen a few people use the come along manual winches. I was wondering if anyone uses one of these and which ones will actually work well with a tj.
I get what you're saying, and I don't want to sound like a jerk, but damn...if you're that broke (only have $50 to your name), what are you doing out wheelin' where your next broken part could very easily cost you way more than you can afford to fix?If I didn’t have a winch and had no budget to spend and I was stuck and had no one to pull me out, I would probably go buy this....I’m not a fan of Harbor Frieght, I anything I’ve bought there I pretty much did so because I needed it once and never expected to need it again....however I will say my angle grinder from there has been great. Anyway, I’ve seen this do some good work, you’d probably want to attach to a tree then use something like a heavy duty ratchet strap or chain between the vehicle and hand winch so you can take the slack out as you winch. It would be a GIANT pain in the azz BUT if your stuck and only have $50 to your name and your buddy can’t pull you out....give this and a heavy duty chain/ratchet strap a shot...also maybe a pipe to put over the handle to extend it https://www.harborfreight.com/8000-lbs-cable-winch-puller-69855.html
BUT like everyone said....I’m not recommending this, but I’ve seen it work with a LOT of pita factor....when your buried in a 2 feet deep mud hole you really do need a good electric winch.
Now thats pretty fair ill just have to go with friends and i should be fine but one other thing i have ready is using a highlift with tow chains and stuff like that to be used horizontally instead of verticallyI get what you're saying, and I don't want to sound like a jerk, but damn...if you're that broke (only have $50 to your name), what are you doing out wheelin' where your next broken part could very easily cost you way more than you can afford to fix?
Sorry, it's just the first thing that came to mind when I read your post. No offense intended...
Oh hell no. That thing is a Chinese made bomb waiting to explode, in your face.
Yes a flip flop winch. I carry two 10ft posts strapped to the top of my rig with 200ft of strap. Those fancy electric winder things can break on you.Forget about the bumper mounted winch, here's the way a real men do it.....
https://wranglertjforum.com/threads/winch-sticks.12459/
Now you tell meI just carry a hatchet and the strap, unless I'm planning to get stuck.
