I need your help, I want to create a comprehensive list of spare parts that are good to carry in my Jeep. Common issues that may occur, the parts you should own and the fixes. The goal is to have one spot where people can become familiar with, and be better prepared if an issue arises when you're out in the world.
To give some context my transmission linkage popped off during a recent trip when I was out in the middle of nowhere with no cell signal, I didn't realize it was a common issue that people keep spare parts for until after the fact. I think this would help a lot of jeep owners
42RLE Transmission Issues
42RLE Transmission Linkage
Symptoms: There is no play in the shifter when changing gears and cannot shift gears
Part: https://www.amazon.com/gp/product/B007NPDSAE/?tag=wranglerorg-20 (Mopar PN: 68137495AA)
Fix:
(I assume its just as simple as putting the bushing in.)
A better fix: https://www.instructables.com/id/Fix-2006-Jeep-Wrangler-Automatic-Transmission-Link/
Trail fix (without parts): Zip tie the shifter to where it popped off.
42RLE Transmission Shifter
Symptoms: Can't get in/out of park.
Part: Plastic coat hanger or chopstick.
Fix: 2003-2006 42RLE transmission shift interlock fix
All Jeep Issues
Ignition Switch Actuator
Symptoms: Engine will not turn over, starter will not engage.
Part: https://www.amazon.com/dp/B004BYX8W8/?tag=wranglerorg-20
Fix:
(NOTE: some specialty tools needed)
U Joint Failing
Symptoms: Play in the wheels, or play in the driveshaft
Part: Rubicon:
(need help here with all the PNs for the different years)
Fix: TBD (finding a link later)
Feel free to comment more issues, corrections, or any better documentation and I'll keep the above list up to date.
Fix:
All Jeep Issues
Fix:
U Joint Failing
Part: Rubicon:
