Been back and forth on this for some time, I think finding out what it's worth might give me the push I need. I'd like some opinions from Phoenix locals on what they think this is worth. I'm probably forgetting some stuff but here's a list of what's done to it
2002 Jeep Wrangler
5 speed NV3550
188k miles - Motor has about 140k - Speedo has been between 10%-15% off so mileage on the odometer is higher than reported
Transfer case full rebuild @ 180k
New Bestop Trektop NX
New 35x12.5r15 Cooper STT Pro tires w/ Discount Certs
Black Rock 909S Wheels
Suspension
AEV 3" progressive coils
OME Nitrocharger Sport shocks
JKS 1.25" body lift
Rokmen adjustable short arms (all 8)
Custom front trackbar
Metalcloak rear trackbar
Currie Antirock swaybar
JKS rear swaybar link extensions
Axles
HPD30 front, Artec trussed and gusseted, Currie Johnny joint axle upper control arm mounts, 4.88 gears, 27 spline ARB locker, New spicer ball joints
Superior axle and gear 27 spline chromoly front axle shafts
Spare stock 27 spline axle shafts
Dana 44 rear, 4.88 Yukon gears, 33 spline ARB locker, ZJ disc conversion with Centric parts
Ten factory 33 spline rear chromoly axle shafts
Spare 33 spline Superior Axle chromoly axle shafts
Drivetrain
Bosch 4 port fuel injectors
M.O.R.E. Bomb Proof Motor Mounts
Novak shifter cable
JBC Super Short SYE
Tom woods CV rear drive shaft
Front driveshaft rebuilt with Spicer parts recently
UCF lopro transmission mount
High flow cat and dyno max super turbo muffler
Armor
TnT Customs Phantom front fenders
UCF Ultra High clearance skid system (transmission and engine)
Metalcloak front bumper with stinger
Warn M8000 winch
Groundpounderfab custom rear bumper with swing out tire carrier
Savvy rock sliders
PSC Steering Box Skid
Electrical
Brand new Odyssey Extreme AGM battery
1AWG battery harness
Dodge Durango 160A alternator
JVC Bluetooth Radio
Cobra 29 LTD Classic CB Radio w/ Firestik Antenna (4' and 5')
Hella H4 Headlight housing w/ IPF Fatboy Bulbs
Steering
PSC Ultimate Steering kit (high performance power steering pump, reservoir, cooler, steering box and hydraulic ram)
WJ knuckle and caliper swap with centric brakes
Aluminum one ton OTK steering upgrade with high steer and FK heim joints
Genright twisted pitman arm
New intermediate steering shaft
Borgeson heavy duty upper steering shaft
Misc
ARB high output medium duty compressor
Custom rock lights
Maintenance (just some of the bigger stuff)
Oil changes every 3k miles, usually Rotella T5 10w-30
Amsoil Sychromesh transmission fluid
Luk clutch, flywheel, fork and related replaced @ 150k
NTK Oxygen Sensors
Timken front wheel bearings
New Denso AC Compressor, Condensor, Drier, High Pressure hose
Gates Belt, Mopar Tensioner, Idler bearings
Timing chain @ 173k (preventative with timing cover leak)
Mopar Water Pump, Mopar Radiator, new hoses, coolant
I have a general idea of what I'd ask for it, I usually start high and lower the price if I have no bites
2002 Jeep Wrangler
5 speed NV3550
Suspension
JKS 1.25" body lift
Axles
Drivetrain
Novak shifter cable
JBC Super Short SYE
Armor
Warn M8000 winch
Savvy rock sliders
Electrical
JVC Bluetooth Radio
Steering
Misc
Custom rock lights
NTK Oxygen Sensors
