Make sure your winch can use rope---after talking to a tech rep at Superwinch, he told me my model will transmit to much heat to the rope so don't install it-—--I found this out after buying my winch. later models are ok
Other then weight, why would you replace your steel cable with synthetic?
Yes and no. In the normal 'in' direction we use our winches it's true they don't generate heat through the drum. But if you were using it in the 'out'/reverse direction like if you were lowering yourself or someone else backward down over the edge of a cliff then the internal drum brake could generate enough heat through the drum and damage the rope.That's a myth
In normal uses I found my synthetic rope to hold up MUCH better than my previous wire ropes did. I replaced my first winch's wire rope twice in its first 4-5 years of use. My wire rope would get kinked during normal uses and then strands would break. Wire rope won't kink if you are able to rewind the rope evenly across the drum and retighten it after each use but sometimes you can't, like if you need to do multiple winching operations in one day where it's just not practical to respool the rope properly after each use... and that's what can damage a wire rope, like when it gets pulled down through its layers on hard pulls.Other then weight, why would you replace your steel cable with synthetic?
In those situations the winch is being used as a hoist which is almost always cautioned against in the user manuals. They are winches, not hoists.Yes and no. In the normal 'in' direction we use our winches it's true they don't generate heat through the drum. But if you were using it in the 'out'/reverse direction like if you were lowering yourself or someone else backward down over the edge of a cliff then the internal drum brake could generate enough heat through the drum and damage the rope.
But in the normal 'in' direction we use our winches? Nope, heat is not a problem at all.
Very close with a few small things. Abrasion is not good for steel or synthetic. Protect both from abrasion like your life depends on it because at some point it could.ok, so 85ft of TRE 3/8" rope is 179. safety thimble is 75, and a soft shackle adds another 25.
all this comes in under what the M8S would have run, with a better pull rating and cuts the weight like i want.
85' shouldn't overload the drum, and i carry a 20k tow strap that could help if reach length was to become an issue.
abrasion would be a constant concern, and it's potential to hold moisture could pose an issue in very cold temps as well as possible UV degradation with long term exposure.
am i close here?
and thanx for the help.
When I weighed my 100' of 5/16" wire rope it registered 19.6 lbs. The 80' of 3/8" synthetic I replaced it with didn't weigh enough to register on my scale but it couldn't have weighed more than a couple pounds including the Safety Thimble it came with.20 lbs? Really?
Polypropylene is a cheap rope that is often used by boaters and it has little ability to withstand UV and it definitely is not used for Jeep-size winch ropes. Good quality synthetic winch ropes are made from UHMP (ultra-high molecular polyethylene) treated to resist UV damage and they can last many years.i've seen some old dry nasty UV exposed marine ropes. the fiber/strands crack if you bend the radius real tight.
but i believe that's a polypropylene rope. not dyneema.
We've been on trail with a broken rig and had to use my winch at least 20 times for just that one recovery so no, someone is feeding you a line of bullshit.I was also looking into synthetic lines, but I thought I read that a big drawback is that you can only use them four or five times before they need to be replaced? Is that not correct?
Stop reading anything else from where you read that. Blaine's "bullshit" was the best way to describe what you read. My current synthetic rope typically gets used 1-5 times (and sometimes many more than that) each time I go out wheeling and it's over 5 years old now.I was also looking into synthetic lines, but I thought I read that a big drawback is that you can only use them four or five times before they need to be replaced? Is that not correct?
