Constant Tension Clamps
97JadeTJ
Hot Springs, AR
I found several threads on constant tension clamp availability but they where scattered over different sites… I located 1 site where all sizes are available in singles as well as bulk and delivery was in 5 days… https://belmetric.com/…. They also appeared to have other hard to find fasteners… below is a list and quantity of clamps needed along with a link to each
You need 1 42mm for upper radiator inlet
https://belmetric.com/clamp-wide-band-full-tab-constant-tension-9mm-50mm/?sku=CTC42BAND15
You need 2 47mm for thermostat housing and the lower radiator outlet
https://belmetric.com/clamp-wide-band-full-tab-constant-tension-9mm-50mm/?sku=CTC47BAND15
You need 1 55mm for the water pump outlet
https://belmetric.com/clamp-wide-band-full-tab-constant-tension-9mm-50mm/?sku=CTC55BAND15
You need 2 24mm for the small heater hose
https://belmetric.com/clamp-wide-band-full-tab-constant-tension-9mm-50mm/?sku=CTC24BAND15
You need 2 27mm for the bigger heater hose
https://belmetric.com/clamp-wide-band-full-tab-constant-tension-9mm-50mm/?sku=CTC27BAND15
Todd
