So recently, I saw an ad in my Instagram for Wide Open Designs, a company offering 7075 threaded Aluminum links in custom lengths. Now, I'm not exactly sure what length of link would be needed, but knowing that a lower control arm should be 16" minimum length, I'm assuming the link would be 13 or so inches, the price of which on wide open designs is $54. The rod is already tapped on both ends according to whatever specs you want, so then all you would need would be Johnny Joints and Jam Nuts, a part which I can find locally for around $50. So theoretically, if I wanted to get a set of front lower CAs, I could order 2 of the links and 4 Johnny Joints for around $308, then all I would have to do is assemble and install. This might be a competitive option, seeing as Currie LCAs are $380 on Amazon and Savvys are $369. Now if you are ordering all 8 control arms, getting other brands will probably be cheaper than piecing together your own, but then again, Johhny Joints are availible from alot of different vendors and if you could find a 20% off from 4 wheel parts, the price could still be competitive.
