- Joined
- Jun 16, 2016
- Messages
- 5
Hi all, Steve and Linda Rogers here, Payson, AZ. We're new to this forum and real glad to find it. Jerry Bransford, my husband just studied your how-to postings for converting standard to 32RH automatic. He knows transmissions well, having built them for over 20 years and found your postings to be very well informed and so helpful! Very thorough. He's done many conversions both ways on many different makes of vehicles (I'm the "parts finder" for him!) The only question he has and hope you can answer is, when you were talking about wiring - and said "No wiring is needed, the only wiring and connectors you need are already present and hanging above the transmission."
So, the wiring harness on our 1998 Jeep Wrangler TJ (4.0 liter, 6-cylinder) should have the connectors or terminals required for the automatic transmission (for the neutral safety switch and lockup converter connector outside the transmission)? Where are these located on our Jeep?
We have located a good used 32RH automatic and all of the parts to do the conversion in Phoenix (unless someone out there has these components for sale!) but Steve doesn't want to get into wiring difficulties. Also, should the ECM be OK if it's off the same Jeep that the 32RH was in, if our Jeep is a 1998 and the Jeep the auto. trans. is coming out of is a 2001?
Thanks for your help and hope to hear from you soon!
Steve & Linda Rogers
