Also doing IR on heater core hoses. Starting at engine back temp is good when i got to bends in hoses right at firewall and temp drops. Had good flow through hoses when back flushed. Could it be bad hoses?
I doubt the heater hoses are bad. I have seen lower radiator hoses collapse, but never a heater hose.Also doing IR on heater core hoses. Starting at engine back temp is good when i got to bends in hoses right at firewall and temp drops. Had good flow through hoses when back flushed. Could it be bad hoses?
Yes. did you figure anything out yet?Shouldn't heat out of defrost still be around 150 or close at idle?
145 out the defrost vs. my 150. I would be able to live with that.When running on defrost ac evaporator that is right beside heater core hoses were ice cold. I unplugged evaporator and increased my heat by about 10 degrees. While i was unplugging evaporator i also tried one more time to burp coolant system. The reason i did that is because even after driving for about 30 minutes i still did not have any pressure in top radiator hose. Pulled jeep up on steep incline and took off radiator cap and started engine "after it had cooled down of course" turned heat on high and defrost. Kept squeezing top radiator hose and got allot more air out of system and also another member had stated that he had loosened heater core hose connected to metal tube that runs into water pump, slid a small screwdriver between hose and tube and i also got more air out that way. Be careful doing that because hose can come completely off metal tube. I think i had MAJOR air in my system because now i have 145 out of defrost. Still have evaporator unplugged.
I'm going to give this a try since I've had the same issues after replacing the cooling systemWhen running on defrost ac evaporator that is right beside heater core hoses were ice cold. I unplugged evaporator and increased my heat by about 10 degrees. While i was unplugging evaporator i also tried one more time to burp coolant system. The reason i did that is because even after driving for about 30 minutes i still did not have any pressure in top radiator hose. Pulled jeep up on steep incline and took off radiator cap and started engine "after it had cooled down of course" turned heat on high and defrost. Kept squeezing top radiator hose and got allot more air out of system and also another member had stated that he had loosened heater core hose connected to metal tube that runs into water pump, slid a small screwdriver between hose and tube and i also got more air out that way. Be careful doing that because hose can come completely off metal tube. I think i had MAJOR air in my system because now i have 145 out of defrost. Still have evaporator unplugged.
Beautiful. I’ll be trying this todayIt fixed my problem. Burping the heater core hose helped the most
