Cool tools
someguysjeep
simple guy
Lifetime Supporting Member
ohio
not sure many of y'all might be familiar with this bad boy, it's a mag drill.
a HD hole maker that can make holes up to 2" (with this model) . and can hang itself on any solid metal platform, no need to break your arms pushing on a drill overhead........you just have to have room to use it.
they are not cheap, nor are the bits, but i scored this 1 for 300$ a while back, and use it quite frequently at work.
there my new crossmember with 8 big holes that only took about 10m to do.
ay this thread is not just for me.... post up unique tools that others may not be aware of and maybe make someones day easier.
this is 1 i'm surprised very often to hear people don't know about. to me it's a pinch bar. some call it a drift others refer to it as a spud wrench or alignment bar, but it's next to me almost every time i'm working on the Jeep. this 1 is a 1.25" open end they come in several sizes and even with a crecent head. if your doing lift installs or shocks this tool is worth more than all the rest i have scattered on the ground next to me.
I have a friend that calls a cotter pin a "cotter key". First time I heard him say it, I was like WTF is that?
When I was young I heard, and probably said, both cotter pins and cotter keys. If I had to guess I'd say the term cotter key is used on the same equipment as a farmer nut. Since google can't help with farmer nut, it's any of the many square nuts used on (square head) farmer bolts that held everything together a century ago.
Well what do ya know, google does have one link to where "farmer nut" is used. It's someone I don't know, wdTom that said, 17 yrs ago, "I have called (fondly) square head fastners "farmer bolts or nuts" for sometime now." in the 5th post down.
Across the pond they seem to call it a split pin, which seems reasonable.
Reactions: txbemis69
If someone wants the line up ability without the open end wrench I find this set of pry bar and line up tools pretty much indispensable.
I think these are referred to as a rolling head bar.
Also in the OP‘s thread about the mag base drill he shows a cutter that’s the cat’s ass for drilling frames etc.
A popular brand of that type cutter is the Blair Rotabroach
http://shop.blairequipment.com/Rotabroach-Cutters-s/2.htm
I have the individual Blair spot weld cutters in 1/4 thru 9/16 for thinner metal and sheet metal.
Some of those mounted on arbors are shown below the blue kit box.
I also have the larger hole kit shown below for up to 3/4” holes in thicker metal.
Expensive, yes but so is a set of quality 1/2 thru 3/4“ reduced shank drill bits.
IMO worth every penny when drilling a frame etc.
There is much less torque applied to your body using the Blair cutter compared to a large drill bit in thick metal.
Nice clean round hole as well.
If I’m drilling a thru hole I usually drill a pilot hole the diameter of the pin in the bit arbor and don’t just rely on a center punch mark.
Reactions: Sea Cot
Yes they do.
Thankfully they survived a copycat, imported tool, that was available in the 80‘s and 90’s.
Edit: Looks like I misspoke, the original maker of the tool, Pootatuck, seems to have gone out of business quite awhile ago. Too bad.
I had a chance to use the original tool as well as a knock off years ago in a picture framing class. The original was hands down the better tool. Surprised?!
