@TJ4Jim This is my set up for making picture frames,
but being able to fine tune a troublesome corner would be really handy
Nailed a Jet benchtop mortiser on FB Marketplace for $160 today.
Aaawesome !!!not sure many of y'all might be familiar with this bad boy, it's a mag drill.
a HD hole maker that can make holes up to 2" (with this model) . and can hang itself on any solid metal platform, no need to break your arms pushing on a drill overhead........you just have to have room to use it.
they are not cheap, nor are the bits, but i scored this 1 for 300$ a while back, and use it quite frequently at work.
there my new crossmember with 8 big holes that only took about 10m to do.
No relation to CAT-equipment, a buddy of mine cut the emblem on his programable plasma tableOpen end hammer wrench
Size 11” or 280 millimeterView attachment 255253i have yet to weigh it ,
Great piece of machinery, they have not changed much looks just like my Porter Cable. That work light is handy where did you find that.My bandsaw was literally a barn find. I bought it in rough shape in the mid 90’s. Added a 3/4 Hp motor about 20 years ago.
Originally built in Tupelo, Mississippi in 1953!
With the correct 1/2” blade it will resaw a red oak board like a champ. (Note 1/4” boards stacked in the background of the first photo)
I have a cheap plastic version that I’ve had for a few years. Love the clean end break, no sharp edges!!Panduit zip tie tool. Adjustable tension, cuts flush, no jagged ends. I’ve got a couple sizes.
Can double as a cerakote oven too. Just sayinHere's a current tool project. I'm building a powder coating oven that has interior dimensions of 48"H x 24"W x 18"D.
All cool ideas! The punch holder would have saved lots if skin and a few less blood blistersHere are a few small things that I made.
A holder for punches and chisels. It's basically a ground rod clamp with a plastic handle, a piece of threaded rod and a wing nut.
A MIG torch holder out of a 45* piece EMT conduit and a magnet.
Wire routers out of brake line and old screwdriver handles. Great for feeding wire up under dashboards for example.
A hose hooker out of an old awl.
A spark plug tester.
Wow this is awesome!!! Would love to see it in action with a video after overhaul. Are you putting a new motor in?Another one of my recent Craigslist finds and future restorations. It's a small (450lb) Zewo radial arm drill. Has about a 2ft arm with a 4" diameter column. Can rotate 360* slide left and right on the arm and the arm will pivot 90* in each direction to drill sideways or at any angle. All japanese made and was a high quality machine when new, hand scraped table and sliding surfaces. The table is in good shape, just need a good overhaul and it should be good as new
View attachment 255698View attachment 255699View attachment 255697
