Got a coolant leak on a 2006 LJR and am looking for some advice on where to look next.
TL;DR:
Radiator and fan assembly is <1 year old, heater core is of unknown age. Haven't done any off-roading in the last 6 months and driven mostly highway/suburbs. Heat works fine, AC works fine, no leaks in passenger seat (indicating heater core failure). I added ~5 quarts of coolant over the last few days. I am planning on doing a coolant leak dye test this weekend to confirm heater core concern, but I'm guessing that there is most likely coolant evaporating somewhere else in the chain. One other thing to note is that the overflow chamber would bubble after driving - I figured this was normal and has been doing this since I've had the vehicle (please let me know if it is not).
Background:
I was driving the other day and noticed the "check gauges" light on and that my engine temp was in the red. Pulled off immediately to kill the engine and waited about 15 mins before starting up since I was about 5 mins from home and could take a look there. Cranked the heat and drove about 1/4 mile before it overheated again.
At this point I popped the hood and looked at the coolant levels and noticed that my overflow chamber was completely empty. I added half a gallon of coolant (until overflow chamber was maxed) and drove home. Engine was fine on the way back sitting around 210. I hadn't been watching coolant levels so I thought there might be a small leak and would keep an eye out over the next few days.
Added another 3 quarts of coolant today and drove back/forth to the gas station. I noticed a lot of fluid dripping from the AC condenser drain, but it was 95F out and I was blasting the AC so I didn't think much of it. Did a test with the heat blasting and didn't have any liquid dripping out or pooling in the passenger seat, so I think I've eliminated heater core as an issue.
TL;DR:
Background:
