- Joined
- Nov 16, 2015
- Messages
- 7
I have a coolent leak in my 1997 tj se and I thought it was coming from my lower radiator pipe but it seams to be coming from somewhere els. I need some help!
Thanks! The jeep will make a loud high pitched noise for about 20 seconds and then it goes away. The Coolent leaks slow some times and fast sometimes it's not a steady leak. I think you are right I looks to me that it's the water pump.That sure looks like it's coming from the water pump. Any unusual noises? The water pump will start leaking from its weep hole when it's on its last legs.
Bad thing is if you replace one, might as well replace them both.While your at it order the heater hose tube that threads into the water pump, good time to replace that also.
