Which way does the writing “Jeep” go? I think writing up in regards to the valve stem.
Opinion time, 180* opposite from pictured so that when it’s on the back, valve stem is down and Jeep is readable
Realistically, however I happen to slap it on.
Can you say OCD?
Yes, I have a mild case of OCD, and I agree with KingCarGuyZ. That's the way I've been clocking center caps since the first time I encountered the question of "which way should I do it?" I'd tell you my thought process on how I made that determination, but then I'd have to kill you...
The greater question is how do you keep the Jeep logo level on the 4 wheels on the ground !
oh com'on, I told you how I figured it out - you have to share for intellectual research (and so we can all razz you)
The correct answer to this question occurs after the consumption of several "adult beverages", after which it will become abundantly clear!
Well dang it! I was rotating the tires and greasing all the zerts when that question popped into my brain.
Next time, grease the Zerk fittings instead, and the answer will come to you.
Might have been too much Jim Beam
https://zertnation.com/
I can't believe I just wasted 15 minutes of my morning looking through that place
