I decided I'm just going to get off my ass and install my OME 2.5" lift, Savvy control arms, and tummy tuck myself. It's going to take a week or so having kids, but I'll leave the Jeep in the garage and do it over the period of a week or so.
Anyways, before I get started, I just want to cover my bases and make certain that I'm doing things in the correct order.
That being said, I'd appreciate any experts chiming in and telling me if anything is out of order in the installation process:
Front Suspension
Rear Suspension
Same as the front I'm thinking, no?
I just want to make sure I'm doing this in the right order is all, since I only want to have to do it once!
Front Suspension
- Once the vehicle is on jack stands with the wheels removed, remove the current shocks and springs, then install the new Savvy lower adjustable control arms.
- Once the lower control arms are installed, adjust the lower control arms so that the spring lower spring perches are dead center with the jounce bumpers. This should mean my axle is centered in the wheel well, right?
- Remove the front upper control arms and install ONE of the Savvy adjustable upper control arms. Get the front pinion angle aligned properly (How should it be aligned in relation to the front driveshaft?), then once it's aligned, adjust the second upper control arm and install it so that there is no tension or bind whatsoever.
- Install the front shocks.
- Put one front wheel on and jack up the axle (on the side with the wheel) so that the jounce bumper fully hits the lower spring perch.
- See if my tire is contacting anywhere on the fender / fender flare, or if anything else is binding underneath, and set the bump stop accordingly.
- Once the bump stop is set, install the front springs and reassemble everything.
Rear Suspension
