Which gear ratio do you have in your differentials?
I'm assuming the color coordination is more than just different colors here? Maybe Green is the ideal place you'd want to be? In my case I know I'm running 33's and sitting with 3.73 and my gear would be a 30 tooth gear. But the ideal would be for me to upgrade my diffs to 4.88 and run a 39 tooth gear because it's green. Am I reaching here?With that disparity in true mph; I would say 3.07s.
The tire you installed is approximately 31.65" and the closest you will get to calibrate the speedo with 3.07s would be a 26 tooth gear.
Yes I think you are reaching but if you want to look at it that way, I think what you want is to be somewhere in the middle of the range which should give the best balance of on-road and off-road performance. For you, 4.10s would put you directly in the middle with 33s.I'm assuming the color coordination is more than just different colors here? Maybe Green is the ideal place you'd want to be? In my case I know I'm running 33's and sitting with 3.73 and my gear would be a 30 tooth gear. But the ideal would be for me to upgrade my diffs to 4.88 and run a 39 tooth gear because it's green. Am I reaching here?
