I normally leave secondary design elements such as non-crash/impact XMBRS until the HDPTs (Suspension Locating Points) are “warm & fuzzy” , the “Dot Connecting” surfaces such as suspension brackets are then defined the strain contours to either the initial Frame Rail Geometry (shown) or modifications of same.
The JTOE/JT25/JT40 are complete frame assy as “mostly” imaged. The suspension geometry/Engine/Trans/Steering mounts will be predefined (as per drawing) and not modifable by the end user ... the intent is to be a “Bolt-on build”
For End-Users that wish the JTOE/JT25/JT40 to have other than the pre-specified geometry, Special adapters for all brackets will be installed lin lui of, to allow Machined Metal Fittings to be attached to the Composite Frame. This ensures that the Frame is allways receiving Forces/Moments in the correct locations up to the defined limits of the Frame/Brackets/Adapters.
The Lower Frame between Axles will have a User Replaceable Cover/Layer for Sliding/Scraping/Gouging ... 2-3G GVW “Loadings” onto single Frame Rails will be simulated and if required demonstrated, 1.5G (GVW) scaping will present no structural damage but obviously the Cover will not look pretty...
I will be posting Additional Images as I Freeze TJOE designs for Rails/XMBRs, and bracketry over this weekend. Initial FEA Static Deformation Plots will be be uploaded early next week ... Followed by the TJ25 and TJ45 Design/Simultaion Packages.
I was thinking to have a Drawing/Static Simulation for the TJOE Steel Frame ready first ... however the increased effort to create the additional weldments convinced me to delay that effort ... most users are fully aware of how much flex they already have ....
The LJOE/LJ25/LJ40 design will start after upload of the TJ series
Full Disclosure: I have over the years accumulated a lot of specific acronyms ... and I admit to using them far too often ... I am lazy in that respect ... apologies ... pls call me out on my overly gratuitous use of them! ....
r/
