Hey Mike! .... I guess the TJ term will refer mostly to the shape of the Body Panels in the end ...
I was not aware of Hemi swaps ... guess I need to expand my understanding of Extreme Jeeps a little ...
Your are correct in thinking “family” for the Ladder Frames ... but only in a very technical sense ... Commonality for Design/Test Process, Constituent Materials, Component Parsing/Functionality, Manufacturing Process, Inspection Processes, and where sensible ... Geometry (reduced NRC for Tooling). So Yes Broncos, Blazers, Land Cruisers, Susuki, Land Rover, and my favourite the Scout!. In fact any BOF ladder frame vehicle that is out of production could benefit .... up to a production limit of 250 Frame Types/Configuration per year. Quantities above 250/y for any one configuration type require additional automation due to the different Manufacturing Process.
Yes it will be quite “busy” up front with an engine drop ... one of the reasons for a geometry and weight revision to the Axle Housing ... same Ring/Pinion, and Shafting but increased Transverse Bending/Torsional Stiffness with Composites...
The key to available space/clearance for engine dropping, is in the Jounce Limit of the axle housing ... only rock climbers will utilize max Jounce and then on a single side ... more or less a roll rotation of the axle about the vehicle CL ... Full compression/BumpStop contact should only occurr when “dropping” the vehicle (limited to 2.5m).,. my thoughts at least.
