I'm not sure what you're asking either...but I'll try to answer you.
Factory arms are a really good design. The u-channel allows more flex than just the bushing alone. Then you go low end, non-adjustable aftermarket arms. They will be a poly bushing, probably, and they are garbage. They won't flex as well as the factory ones, plus they are fixed length
Next step up would be an adjustable arm with some sort of poly bushing. Still limits flex and stresses the mounts...but at least you can start to control pinion angle, caster, and axle position.
Now we're getting into flex joints. Basically, anything used here for an arm is going to be PLENTY strong for a control arm. The joints are what you're paying for and what you need to pay attention too. Anything that uses a threaded ring to set joint preload is not going to work out long term. The rings loosen up, or the races wear, they just don't last. That includes most every joint out there (RE, Rough Country, Rock Krawler, etc)
Next is Metalcloak. The Duroflex joint is bonded to the sleeve like the factory joint and it spins in the housing. Some people have had good luck with them...some think they contribute to axle wrap. I haven't used em, so I can't say one way or another...but I do know that Metalcloak tends to be more marketing than good product.
Finally, the "go To" best is Johnny joints. Clayton, Savvy, and Rock Jock (and I'm sure others) use the Johnny Joint. The guys out west love em. Here in the midwest, where we deal with Mud (clay type that sucks the oil out of grease)...I'm not sure I like em. They are VERY flexible and robust...but its very tough to keep them in good shape due to the difficulty of greasing (that is a whole different discussion).
