Where engine oil is concerned I once read use as thin as possible, as thick as necessary. Makes sense to me too.
The majority of engine wear occurs during each cold start before the engine oil has had a chance to thoroughly circulate throughout the entire engine. The thicker the oil, the slower it's gonna take to get into all of the nooks and crannies. This is why expensive engines like on some aircraft have pre-oilers to circulate the oil before the engine is started. It saves a lot of wear on such engines. And the higher the cold viscosity, the 10W part of the viscosity, the slower it is to circulate when the engine is cold. Higher viscosity = thicker.
But if anyone really thinks they need to run an extra high viscosity oil that's no skin off my nose. I run the viscosities the Jeep engineers recommend, it's good enough for me.
This is out of the TJ's owner's manual. Where viscosity is concerned, I'm perfectly happy with what the factory recommends. It works for me, I've yet to ever have an internal engine problem in something like 50 years of vehicle ownership. The factory recommended viscosity is all I've ever used so it must be ok to do so.
