This is a flex plate from my 97 2.5L 3 speed 30rh transmission.
The pencil is pointing to the main crack, but look closer and you can see cracks around the circumference of the center hub.
I dont.know why this happened and I couldn't get a straight answer from the transmission shop that did a complete overhaul 1 month ago.
From the looks of the other cracks it wasnt far from a catastrophic failure.
Initial symptom was a metallic noise coming from under the bell housing.
Other symptoms it caused:
...misfire cylinder number 3;
... a loping idle, as if it had a racing cam (it actually sounded cool)
... and a undulating driveline vibration at Hwy speed. It would vibrate for a couple secs then fade away then come.back, etc.
Now its fixed (it better be) and runs good with no vibrations. So far.
