Thanks for the responses. Sorry for not being clear. It does crank but does not start still. Same issue as at the original problem.
Let me know how it turns out
Did you ever get it started a friend of mine has one doing the same thing and we have tried everything. ThanksThanks for the reply. I'll make sure to give the throttle body a through cleaning for good measure.
I have the same problem On 1998 jeep TJ no spark no fuel pressure and crank but no startPlease don't use terms that aren't clear... "come on"? "kick it on"? Which of those mean start or crank? Huh?
Did you figure this out? I’m desperate over here for an answerI’m having the same problem. If you got your to start plz tell me what you did.
If you're saying your headlights dim or shut off while the ignition is in the Start position and the starter motor isn't cranking your engine, that means you either have a dead battery or a bad/loose/corroded connection at the battery.Did you find out this problem? I’m having the same problems. Crank won’t start, headlight issue
